Where did all the banned Headers go?
joesloppy
Post by joesloppy »
If I 'delete' something and click the "Show Deleted" button - there they are.
But where can I show 'banned' headers that I have 'banned' using the filter dialog? I am banning pars so that won't automatically download, but if I do need one, I need to show them. Or should I do this a different way?
Thanks.
in the filter dialog you can press 'undo' to undo the previous ban or to undo everything by pressing 'reset' (or invoke edit menu->reset filter).
if you are using a filter in properties->kill filters, banned headers are deleted so to see them you invoke edit menu->show deleted headers.
