Unable to download bodies
Newscrazy
Post by Newscrazy »
I can successfully download headers for any group, but when I try to download bodies I get "Couldn't mark for download - no servers attached or enabled. Ensure the newsgroup has a server or servers attached and at least one destination server enabled."
I've tried "re-attaching" servers, etc. but nothing has worked.
Please help.
Re: Unable to download bodies
in the view menu->workspace, the leftmost "Newsgroups" tab, right click on the topmost Newsgroups entry, then invoke advanced->attach all servers.
in the second "Servers" tab doublecheck you have any servers, if not that edit menu->properties->servers, doublecheck at the bottom that "get bodies" are checked for every server you want to download bodies from or you can check "always" under "get bodies"
Newscrazy
Post by Newscrazy »
The second item did the trick Alex. Thank you so much!
(and also thanks for the quick response)
Happy New Year :)
