I mean, I can search, but can't import from search results.
I never use UE for downloading, only for searching. I either download nzbs (if they are present) or import and then create nzbs. I mainly use SABnzbd or sometimes Alt.Binz.
Question/feature request:
Please, make it possible to create/exporting to nzb straight from the search results. It is extremely annoying to always import and only then export to nzb. Example: I want to export a whole season of episodes to separate nzbs. What I need to do is:
1. import an episode
2. UE automatically switches from search tab to import tab
3. I need to switch back to search tab and import next episode
And repeat... repeat... repeat...
