I'm too stupid for the RAR password setting
jd
Post by jd »
1. I search something via the search or I import a NZB doesn't matter.
2. UE stops downloading because the posting is passworded.
3. It advised to set the RAR password, which I do.
4. Downloading does not continue after set the password. Why?
Instead I uncheck the RAR password check, the download continues and it's also unpacked at the end - I have the correct password.
What am I doing wrong?
Re: I'm too stupid for the RAR password setting
Can you give me an example?
In particular, do you see all the article tasks shown in the unpack pane right after the first file has been saved or they don't appear and files are added e.g. to a rar set entry only after saving (i.e. no association)?
As it works for now UE tries to find unpack task corresponding to the article task before starting the download, in the case of "bad" subject there will no association.
I could add it will check the rar file name taken from the article being downloaded.
jd
Post by jd »
Thank you, I will look out and give you an example the next time it happens. Maybe send you a NZB.
Got your sample.
Check the version currently on the site, if you hold ctrl while invoking help menu->about you'll see v4.4d or higher.
It should work on posts of that kind.
