Search timeout
Contact support if you cannot find something or experience any other problem with the search service.
swent
Search timeout
Post by swent »
Search service has been timing out (6) for four or five hours.
dwhite32
Re: Search timeout
Post by dwhite32 »
Snap, same problem for me
Black76
Re: Search timeout
Post by Black76 »
Yes, same here as well - "Search failed (6)..."
grenouillle
Re: Search timeout
Post by grenouillle »
Same here. Search Service still has time out problem [6].
Zen
Re: Search timeout
Post by Zen »
Yep, I too am getting timeouts. Hopefully just a simple case of temporary system downtime.
Black76
Re: Search timeout
Post by Black76 »
Hmm, still down. Almost 14 hours now :(
Re: Search timeout
i had internet connection down and didn't get the alarm when one search service computer went down due to failed battery (known issue), the replacement battery has arrived already and will be installed shortly.
search is working now.
i'll try to run sim card modem in the future if such prolonged isp outage happens again, i have never had such coincidence.
Black76
Re: Search timeout
Post by Black76 »
alex wrote:i had internet connection down and didn't get the alarm when one search service computer went down due to failed battery (known issue), the replacement battery has arrived already and will be installed shortly.
Ok, good Alex. Is the search index updated correctly?
Re: Search timeout
it is now up to date.
such situation is rare and i can reduce downtime even when my isp connection is down.
i'm working on sets for search to reduce hardware needs, it should add more tolerancy as to hardware failures.
