Backing up the database to another drive/disk
bruce73
Post by bruce73 »
Just had a hard disk failure, didn't have the NewsPro database backed up anywhere, so had to completely start over. :mad:
What's the most efficient way to backup the database? If I copied all of the .dat files would that be sufficient, or should I simply copy the entire Data folder?
search forum, i remember the question was asked several times.
most important to save reg.dat (most settings), fld.dat (folders)
if you use filters save the filters, wch.dat (watch), flt.dat (kill filters)
pst.dat - post associations and identities
pub.dat public server search.
headers and info about deleted/read, but the files are big - hdr.dat, del.dat (not necessary to save them if it is only for such emergency as hard drive failure).
bruce73
Post by bruce73 »
Really, the only thing that was tedious was to set up all the servers and newsgroups again. So I guess saving the reg.dat, fld.dat, pst.dat, flt.dat would be good enough.
Thanks, Alex.
