Anyway yet to save the Subject or Author info with File?
joesloppy
Post by joesloppy »
Anyway when saving a file to somehow save the Subject info. or Author info. with it, such as in Windows description info. or an descript.ion file. There is a great program called ionengine that auto sorts files by using the .ion file, by author or subject, really nice for lots of downloads at a time and makes easy sorting.
Thanks, Nathaniel
newspro can log saved attachments (properties->general, saving attachments).
check the 'other' section there is a program that can parse the file.
