common setting gethdr should stay ON, how?
Sat2All
Post by Sat2All »
when I start newspro the common setting gethdr is always off. is it possible to leave this setting on? when I turn the setting on and click ok ALL newsgroups are loading new headers? why. please help.
newsgroup -> properties -> watch/auto -> common settings, gethdr is off
Sat2All
NoNo
Post by NoNo »
Hi!
This feature is related to "Enable auto get headers" in the tasks menu
I u need to download headers everytime u start newspro make sure u unset "Disable auto get headers on start"
If I remember u need also to set a "get/rescan headers every xx mins" for the groups u're interested.
Sat2All
Post by Sat2All »
Yes it works now, thanks I didn't know of the feature "Enable auto get headers" in the tasks menu
Bye
Sat2All
Bug?
Post by Sat2All »
When I now start newspro all headers from all groups will be downloaded. also when in the watch tab only boneless is selected to get headers every 15 minutes. is this a BUG of the program? who can help.
Sat2all
when you start the program it will download headers from all newsgroups with auto-download headers set to some time (it won't download headers automatically when the field is emtpy - you see "off" in the gh/rescan column for respective newsgroups).
Sat2All
Post by Sat2All »
thanks Alex it's solved now. I only had set the watch and save to off and thought that the get header didn't matter because of this.
Best regards,
Sat2All
