I will not use newspro for at least a week. So I think it is cleaning time.
I want to remove all .npr files and my question is: can i do that without
getting in troubles? Also: could i remove other files savely?
Should I do something after deleting them?
I'm not sure if I could read the answer soon but thank you in advance for replies.
Bassie
can i delete all .npr when i am doing nothing with newspro?
blackdog56
I have done so without any problem, allthough I think it more proper to do a global search for messages with bodies and then delete bodies for all of those. I ususally just sort my data directory by date, and delete .npr files that are earlier than anything I am currently downloading. The .npr files are message bodies, which may be parts of an old multipart download that never showed up complete, etc...
