Filter Window size
Bert
Filter Window size
Post by Bert »
Hi Alex,
I use a lot of filters which I apply with Alt-Z.
A dialog box appears and I have to scroll to the desired filter.
There is an option to resize the filter window, but the size isn't remembered when closing Newspro.
Is it possible to remember the window size, just as with the save dialog window?
Bye, Bert
it is the windows dialog, it wasn't resizable before winxp (or win2k), for earlier systems i'm not sure resizing will work (without resizing all controls in the dialog) so the code would need to check the system version.
