website not working with leading www
OliMuc
Post by OliMuc »
just wanted to let you know that http://www.usenetexplorer.com seems to be broken (http://usenetexplorer.com works).
The links within UE (Help - About - Homepage) however refer to the www one.
Seems to be a DNS Issue ... I can ping usenetexplorer.com and can't ping http://www.usenetexplorer.com (No DNS Entry)
Regards,
Oli
Re: website not working with leading www
I think it is how web hosting handles it (I chatted with them they have no idea), it looks like old IE and google chrome don't have problem with this.
When pinging from command prompt it removes www. unlike when pinging http://www.google.com
I:\Documents and Settings\daemon>ping www.usenetexplorer.com
Pinging usenetexplorer.com [66.7.211.164] with 32 bytes of data:
I:\Documents and Settings\daemon>ping www.google.com
Pinging www.google.com [216.58.196.228] with 32 bytes of data:
