Re:retention
If you cannot find something or experience other search problems, please
contact support. If it is not a post issue sometimes filters can be adjusted.
Killer Skunk
Re:retention
Post by Killer Skunk »
"November 20: The server affected by the ransomware attack had the system reinstalled and it has been upgraded (RAM, disk space). I'm in the process of copying data from another server. Even as there is more RAM, for a subset of groups I will try to run mid retention range in the compact mode using sets as the server then starts several times faster and consumes twice less RAM, we'll see how it goes."
Does this mean long time retention will come back later or not at all?
With NZBKing being gone too, the long time retention suddenly has become a real issue.
I've had a hdd crash a few month ago and lost all my movies, i've been havily lending on ue, nzbking to get the older items back.
Anyways i hope eventually the retention will be as how it has been.
Re: Re:retention
As far as I can see there is no loss of header data, I'm just copying it first before trying anything else as for some of data I have only one copy on another server.
There was backup disk, but it was plugged in when the server was compromised.
The issue is unlikely to happen again, as the server rdp port is no more directly accessible, the server was running on windows xp as consumer grade later windows have problem with handling memory for such kind of application, it is now upgraded to much later windows server. Windows XP was reinstalled in September, the 2019 rdp patch was applied, but it maybe somehow it wasn't effective, otherwise I don't see how it could happen.
I'll try to engage the second server within a week after it will start downloading headers for all groups.
There was also hard drive loss on the working server short time before the other server was compromised, otherwise I would have two copies on the functioning server, so I'm just being careful. For example I don't want to download headers with high intensity hard drive load and at the same time copy terabyte of data to the same drive. It will cause some delay, but as I will have more backup there will be less likelihood losing header data.
So I kept 4 copies of data, it is the first time when it was reduced to 1 for some of it which is somewhat interesting to learn.
As to retention I'm planning to run full retention, in addition I'll try to use the compact mode on the server side (sets) for subset of groups so the server will use less RAM and as retention grows there will be enough RAM left to index more data.
Right now the server which is being restored doesn't download headers for the largest subset of groups, but the file needed for that is currently being copied and within a day there should be enough there to run the server as backup.
Re: Re:retention
the search service is now working at full retention, it is better than before even with the remaining mid range retention gap for some groups as the prior retention was less than full 5250 days.
the mid-gap will be filled maybe after 24 hours (but i think in those years most posts which were cryptic already are not referenced from any website, so they are mainly just dead weight) and copying process will be finished maybe within one week from now so there will be enough backup.
Killer Skunk
Re: Re:retention
Am getting very good result again Alex, just grabbed several things from over 4500 days and it just finds it without a heartbeat. Thanx for all the hard work.
