Feature request: on the fly Par & Unrar
tijgert
Post by tijgert »
This function is already part of SabNZB I believe and I feel it would be a valuable feature for UE.
As it is now, when downloading large archives (like a 50GB movie or game), it takes a long time to download, then PAR check and then unRar the archive. These functions can be done in parallel.
As each RAR file of an archive is downloaded it can immediately be PAR checked to be functional and unRARed. The PAR check and unRAR process will then pause until the next RAR file is downloaded. This way, upon download completion the archive will then almost immediately be both PAR checked and unRARed, ready to be used.
When a faulty RAR file is detected the unRAR process will be halted until sufficient RAR and PAR files are available to repair the archive upon which the unRAR process will resume.
As it is now, of course, after download completion we then have to wait for the PAR check and then the lengthy unRAR and that leaves a lot of SSD performance and CPU time unused.
Re: Feature request: on the fly Par & Unrar
Does it work for .7z files too?
I could try to check it, it would keep the unrar task slot occupied then during the whole download (so would add one more thread).
Very likely there is no waiting option in the unrar command line executable, so such a feature would have to use the embedded unrar code. Others use unrar command line dll I guess, but I didn't want to have a third party dll with potentially different versions running in the UE address space with the ability to crash the whole thing or worse to corrupt the address space with culprit unknown, from other side if the unrar command line executable crashes its process will just end resulting in an error message shown for the unpack entry.
tijgert
Post by tijgert »
I can't say if it works for 7z or regular Zip files, but the vast majority of large archives is RAR.
I suppose you'd only need one thread to do this stepped download-Par-RAR operation for very large archives.
First I need to finish newznab interface since its development was a kind of interrupted, then this could be considered too.
Is the question still relevant? 7.4.4 has been released at last, there was a delay caused by a circumstance beyond my control, otherwise it would be completed in February.
Unrar is very likely manageable in this regard after figuring out synchronization matters. As to .7z I'm not as sure as it would be better to keep the command line utility separate and it doesn't have incremental inflate option as far as I remember.
ok technically it was much easier, it will be v7.5 then.
tijgert
Post by tijgert »
I’m glad to hear that. This way there will be less and less to improve upon. Good work!
It would be interesting to add incremental un7z, logically it doesn't need to know all parts in advance, but the 7z code is written in such a way that it checks the total size first and the cavalier approach to bypass that didn't work, so I thought better to roll back the initial plan and add only internal un7z first - with zero issues so far.
tijgert
Post by tijgert »
There aren't many large 7z archives fortunately, mostly it's all zip and rar.
