[REQ] Column Ordering in Server properties view
Schrijver
Post by Schrijver »
Could you make it possible to apply a sort order in the Server properties view?
I would like to sort the server by priority. Normally a simple click on the Column header would be enaogh, but that doesn't work.
ok i added some rudimentary sort by server priority and user name (the latter to group server from the same provider).
Tha*Lunat!k
Post by Tha*Lunat!k »
Another thing I just remembered... there is no 'Set' button for the server port number. I imagine it isn't a common occurrence to need to change port numbers on a variety of servers, but if it's easy to add with the rest then I'll throw that suggestion in.
it is too rarely needed to change port for a number of servers.
just as to the column sorting it makes sense - priority to see servers in the priority order and userid - to supposedly to arrange servers by provider (e.g. to group newsfeeds servers together if you use unique username).
