Header Auto Update
boston62
Header Auto Update
Post by boston62 »
Can anyone tell me if in properties>watch/autoheader Check Box with SAVE > incomplete partials Should I have this incomplete partials box checked?
If I have UE to update my headers every 4 hours, will it keep updating the articles that are incomplete at the time the headers were updated?
example
Lets say The Hulk which shows at partial and at 50%, will the autoheader updating keep adding to this, until it's complete? Thanks for the help
jonib
Re: Header Auto Update
Post by jonib »
boston62 wrote:Can anyone tell me if in properties>watch/autoheader Check Box with SAVE > incomplete partials Should I have this incomplete partials box checked?
I have it checked so even incomplete files get saved and can be used to repair with par2. But you need to have Save/Unpack->Duplicate file names set to overwrite or UE will save to a new name every time it saves a partial.
Yes, as long as they get completed on the server. Every 4 hours UE will download any new headers.
jonib
boston62
Post by boston62 »
jonib
Thank you Jonib
boston62
Post by boston62 »
jonib
could you explain to me what these settings do? Here is a screen shot of it.
jonib
Post by jonib »
boston62 wrote:could you explain to me what these settings do? Here is a screen shot of it.
As UE can do many tasks like download headers, articles, group lists and post new articles, those settings control what has the highest chance to start next. In your example image, headers has a higher chance to be downloaded than articles.
Hope this helps.
jonib
boston62
Post by boston62 »
Hope this helps.
jonib
sliding to the right increases the setting, thanks for the information.
