Retention settings
Saskia
Retention settings
Post by Saskia »
Hi Alex,
I've been using your excellent program for ages now, and have managed to overcome most of the probs that it's posed, with the help of your website and the info on this forum. But now I can't seem to help myself. My newsprovider is UNS, and they boast having great retention while I think they actually just store a lot of headers without bodies. So I want to limit the period of time over which I get headers in for very large groups (having had a few crashes and getting tired of waiting). So I changed the retention setting from 'natural' to 1-7 to be on the safe side. Now one server (100proofnews) won't get anything at all, and UNS takes a long long time showing a light blue bar in the task manager, and then starts getting headers in at what seems to be the same rate as before. Is this right? Should I try a different setting or just be more patient (grrr... :wink: )? Please help out. TIA, Saskia
in the first time newspro will scan newsgroup for dates; in the next time if you don't change the retention it will be fast since no such scan is needed.
you can set the retention only for uns if your other server gets stuck with xhdr leave its retention natural (if it just wouldn't support xhdr newspro would still work normally).
Saskia
Post by Saskia »
I see, so the light blue bars means it's scanning dates. Thanks for your help, I'll try adjusting the settings for the other server.
Saskia
Saskia
Green bar?!
Post by Saskia »
"Natural" retention seemed to work better for 100proofnews, but now, with another group, it shows a light-green bar. Can you tell me what this means?
TIA, Saskia
